bobbdot - I spent quite a bit of time reading instructions and watching videos to make sure I was take proper measurements. My TT tires are max inflated, the rear tires on the TV are just below max inflation and the front tires are at TV recommended pressure. In all of my measurements and when I went to the scale I had my TV loaded as I would if I were headed out for the weekend. I have all cargo loaded to the front of the trailer. I am still under my GVWR on both the TV and TT.
janechucknicodemus - I took weight off the WD bars as I could barely get them hooked up on the last chain. Do you suggest that is where it should be?
Thanks both of you for your replies.
