Again, thank you everyone for the thoughts, suggestions, advice, etc... I do have a few questions now that I have some input from you.
To answer a previous question I have a 10,000 lb hitch 1,000 lb spring bars.
I feel I have adequate tongue weight with no fresh water in my tank (I'm at 12.5%), should I be filling my fresh water tank which will get me to about 15% on the tongue?
Should all the tires on my TV be aired to max pressure?
My Ford manual says to measure my front wheel well space with no load and then again with the trail hooked up, but no connected to the spring bars. Then adjust the hitch with the spring bars so the front wheel well space is a quarter way down from total desitance between the initial two measurements. What should the space be on the front axle compaired to the measurement when not hooked up?
I'm told the spring bars should be level when hooked up. I do not have enough chain on my spring bars to reach the hooks on the tongue when level, I have to tilt the hitch head up in order to hook up and this leaves the spring bars angled up slightly, is this ok?
