camperforlife wrote:
Retired JSO wrote:
I have read on other forums, the trucks built in anti sway control may be at odds with WDH. Try turning off the trucks anti sway control. Ir will default to on after every shutdown. It made for a better tow with ours.
I just had this conversation with Blue Ox. I wasn't having sway but was getting pushed by wind gusts more than I felt I should. One of my issues was the dealer installed under sized bars so with that point don't blindly accept the dealer set up. Secondly Blue Ox mentioned turning off the factory sway control because it can be at odds with the hitch sway control.
What truck/trailer do you have and what size bars did you have and have now?
Mine is a '11 GMC 2500HD Crew pulling a 35' Cougar. Original bars were 1000lb based of the posted dry hitch of 940 which I argued wasn't right at the time. Actual tongue weight is 1320 and 1500lb bars are on the way.
I have mine at a seasonal but the 1000lb bars I think are too light. Dry hitch weight is 780 lbs but is closer to 1200 lbs loaded. going to see about getting the higher bars and try them. Please let us know how they work when you get them.
