marcsbigfoot20b27 wrote:
When you are sitting on the couch watching tv it doesn’t matter if you are at sea level 20.9% oxygen or at 9000 ft and only 16% O2. You aren’t doing much work so it won’t matter.
Your vehicle will run on 87 octane under minimal load just fine.
Now try and play tennis, basketball, push start a motorcycle etc with low O2 and this is how your vehicle will feel with 87 octane when under a load, the lower the altitude the worse.
It will re tard (wow got censored for re-tard) the timing and you make less torque/power/fuel mileage.
This is an RV forum and most are towing or pushing motor homes so the vehicle is working hard, I would use premium unleaded On a turbo vehicle for sure.
It may re tard the timing, but it also increases boost.
My Eco works the same at 900ft as it does at 10k ft, while on 87.
I personally dont care at all what anybody else uses for fuel in their own vehicle. Use whatever makes you sleep well at night.
