valhalla360
Feb 08, 2021Navigator
rjstractor wrote:BenK wrote:
There is a trick...turn your shank so that the ball is raised higher than the other in a butt to butt pulling contest.
Yours will unweighted theirs and they will add weight to yours.
Also, DO NOT or STOP of your vehicle starts to bounce...if not, breakage of drive train parts
Did you see the article? No mention of any kind of tug of war. They were pulling a tractor pull sled.
Same effect. If there is some downward pull, it will increase the rear axle weight allowing the truck to develop more traction.
If you've ever been to a tractor pull, you will see the front wheels come off the ground...why, they've done this exact thing. When the front wheels come off the ground, the entire weight of the tractor plus part of the sled is on the rear tractor axle maximizing traction.
