Yall may know i have been worried about my payload, and recieved a ton of info from the folks here. Long story short i stopped at a flying J and did two different weigh ins on my way to drop tt off fo...
If GVWR is 6800 and the scales said 5860 you have 940lbs left for payload, you said you removed trailer but also that hitch still on, if trailer still attached but not on scale you can load op another 940lbs, if only hitch on truck you still have to weigh trailer wheals only on scale and deduct from your 11400lbs GV this will give TV weight now subtract this from your GVWR and you have available payload. Frank
