blt2ski
Dec 10, 2017Moderator
Or could be carbon fiber tape/cloth added to stress points, as is and has been done on boats. Then one uses an epoxy or plastic based resin to adhere e everything together.
I personally do not as mentioned see an issue. Unless they try to use in the bed of a pickup where one else do impact loads, IE loading rock of larger sizes with a loader. Even topsoil could cause an issue.
I have seen some flatness with "STARBOARD" or equal plastic bed material instead of wood or steel/aluminum. This seems to be working reasonably well.
Marty
Marty
