I guess the real question you need to be concerned about is do you smell actual combustion; Or is the smell the oils from manufacturing that will burn off after a few hours? All new RV's will stink for a few hours when the propane appliances are first fired up. If you think the water heater is bad, wait until you turn on the furnace. That will stink enough to drive you out of the trailer.
When mine was new I opened all the windows and turned the thermostat all the way high and let the furnace run for a few hours. The smell was bad, but it dissipated and never came back.
