JimK-NY
Jul 04, 2023Explorer II
Depending on where you are in Texas, it is likely hot and/or humid. Either can cause false alarms especially if the heat is causing some out gassing. I had issues with when I did a lot of caulking in the bathroom, also once due to painting the plywood under the mattress and another time with due to a strong chemical odor from a plastic shower mat. The propane detector is especially prone to false alarms even when new but similar issues can cause false CO alarms.
