Bedlam
Jul 05, 2023Moderator
Remove the propane tanks and spray soapy water over the valve to see if is leaking. With the propane sorce removed from the camper, see if you are still getting propane alarms. If so, it is not propane but some kind of chemical off gassing from material in your camper.
If the alarms stop, you have leak in your lines that did not show up until your propane bottle valves stopped sealing properly. This will be harder to diagnose since the lines run to fridge, stove, water heater, furnace and generator. I would try and make a fitting so that I could run a low pressure compressor into the propane lines and then use soapy solution to look for bubbles. I know there is a dye you can inject into the lines and search for where it is leaking, but I have source this.
