themacfamily2000 wrote:
Our carbon monoxide detector has been going off in the middle of the night. We have located no leaks from the outside of the trailer. Do we assume there is a propane leak on the inside or could the sensor be bad? We purchased the trailer in 2011 and the detector says replace by 2015. Is this an accurate replacement date? Also, is this something we can fix or should we take it to the dealership?
Not a lot of information to go with but if it says replace by 2015, I would replace it. First you need to figure out if it actually a CO Detector or an LP detector or a Combined CO LP detector?
This is definitely something you can replace yourself. Just google or search Amazon for the model number on the detector.
