cubbearExplorerOct 02, 2015carbon monoxidewhen I came into shop this morning both carbon monoxide alarms were going off in camper. The camper is pluged in and gas is turned off. any ideas what could set off?
Joe417ExplorerOct 02, 2015We've had several things set off the CO detector. It seems to be quite sensitive. Lysol disinfectant, spray paint fumes, Easy Off oven cleaner, and insect spray. Low voltage cause a slow beep. Makes you wonder if it works with CO.These also set off the gas detector. I've checked this one and gas does set it off. Lucky I don't have a dog.
Related ContentCarbon Monoxide alarm going offCarbon Monoxide Detector Proper Placementcarbon monoxide detectorCarbon Monoxide DetectorCarbon Monoxide detector
