MFL
Mar 18, 2019Nomad II
Mine is a Dometic, but similar, and I use either silicone spray for lube, or WD40 to clean the move able joints. If yours is having a binding issue, between mounting brackets and arms, you may be able to push the whole assembly (while extended) in the direction needed, to relieve the bind. I had to do this once, after the wind had pushed it out of alignment.
The electric motors on these awnings do not have much torque/power.
Jerry
Jerry
