CampingN_C_'s avatar
CampingN_C_
Carlisle Radial Trail RH
Can anyone provide a long term review of these? I've dug around and not really found much 'current' info. I know they got people talking a couple years ago when they came out. I'd like to hear from those that have a few years on them now. Any major failures?
  • Just a bit of info I have picked up on while researching tire mfg's.
    I see the tires you mention are rated for 87 mph . It just made me think of the following.
    You might have to keep the same size tire on the same wheel.
    I would not exceed the wheel and valve pressure rating.
    Some tire mfg's tell customers to add 10 psi so they run them at 66-75 mph. It's not safe to do that on a tire if the wheel psi rating is exceeded. That will limit you to 65 mph.
    Just wanted to share this info to make sure your new tires are a match up for the wheels you plan to use. Many people mismatch them and blame the tires when a failure occurs.
  • Well, as long term as possible. I know they haven't been out very long. Just trying to keep the guy that bought some last month from chiming in. ;)
  • Not sure what you mean by long term, but I've had a set on since last year. 235/80/16, LRE. Got about 3500 miles on them without any issues so far. Tows fine. I've been pretty happy with them.
