I am finally going to pull the trigger on a metal carport and am limited on space. The biggest I can do is right around 24'X 24'. Height is important too and figured 12' with a no gable A-Frame will b...
I would get an accurate measurement of your height (when hooked to tow vehicle) and contact the cover supplier to discuss your concerns and find out from the supplier what the minimum height will be to the bottom of the trusses going across the width of the cover. You might also suggest that the clearance height be put in the contract when purchasing the cover.
