nremtp143
May 20, 2015Explorer
brussie wrote:
I have a question about hauling 2 12' kayaks on the cab of my 2011 ford truck with the use of the thule goalpost , has anyone done this and if so any problems with the cross bar holding up, because I worry about the holes drilled through the cross bar braking.
I am not sure I understand your question. Basically, the setup I have is nearly a copy of the Goalpost. The cross bars on the cab are Thule on mine, and any should work. There is very little weight on the bars themselves. Actually there may even be some lift at highway speeds. I am not sure what holes in the cross bar you are referring to though.
