- JBarcaNomad III carry the complete bearing set, seal and cotter pin. They are in their original packing which helps ward off rust on the race/bearing.
I also carry the grease. If I have to actually repack the bearing, I will deal with greasing the new bearing then.
Since I do my own bearings and brake work I know what I have in there. In the last 14 years I have never had a bearing issue. Really don't expect one but I am prepared in case it happens. Odds are higher you will have brake issue with an electric drum brake. That I have had. And when you pull the drum to deal with it, then that new seal and grease you have will come in handy.
Hope this helps
John - ScottGNomad
newman fulltimer wrote:
if you have a bearing fail you will more than likely need a new spendle as well
Not always and more often than not you can file off high spots, put it all back together and be fine. - newman_fulltimeExplorer IIif you have a bearing fail you will more than likely need a new spendle as well
- westendExplorerI carry a couple in their original boxes. If I spin a bearing on the road, I will be packing it there.
- K_CharlesExplorerThat would be one way to insure a bearing would never fail. If you have one you will never need it.
- LwiddisNomadBearings are generally available.
- boogie_4wheelExplorerIf you are going to carry a spare wheel bearing, carry the whole set; inner, outer, seal, castle nut, and pin.
I would have the bearings packed, ready for install. Store bearings in a freezer Ziploc inside a small cardboard box.
44,056 PostsLatest Activity: Mar 02, 2026
