d1h
Nov 20, 2023Nomad III
Castle Rock
My new TT came with Castle Rock brand of tires. Some reviews say they are great with no problems others say beware. Guess very few manufacturers put Goodyears on at the factory.
If I bought a new coach and it came with Chinese tires, I think I'd try and get a few miles out of them, but not without watching them very very closely. I'd have a TPMS installed and keep a close eye on the tire pressure and your speed going down the interstate.........and I'd be watching the outdoor temps that you're towing in. A 105 degree day heading down Hiway 40 at 65-70 mph could unwind one of those tires............so I guess I'm saying, I'd want to get my moneys worth out of them, but I'd be on pins and needles the whole time.
Interesting article about Castle Rock.
https://thecampingadvisor.com/how-good-are-castle-rock-trailer-tires/
We pulled our 3500 pound trailer with the original Castle Rock tires for 14,000 miles. We have a TPMS on the TT and truck. I will not pull my TT without one. I replaced the Castle Rocks with Goodyear Endurance because nu utility trailers have had them on for a long time without any problems.
Above is all good advice. Some manufacturers do offer Goodyear tires, Keystone for one, and some also offer tpms systems. Add to the sooner rather than later replacement of the tires the need for a monitoring system so you will know what is going on with the tires now instead of what they were. A good monitoring system will save many thousands in repairs and that tire that got a screw in it may also be saved. Truck System Technology (TST) would be my choice.
What you will find is there are blow outs from every brand. Not surprising if 90% of new tires are the base brands, 90% of the complaints are also.
It may also be a bit skewed as people overload and/or run underinflated when they first get an RV. Then after a blowout, they compensate by watching the weight and properly inflating the tires...but they chalk it up to the replacement brand.
Always have bought the off brands as did my Dad. In over 50yrs of pulling trailers, had one blow out but that was a failed leaf spring where the broken end swung out and ate the side of the tire.
I have two sets of Goodyear Endurance tires. For a given tire size, they have a higher load rating than other ST tires.
They also have a higher speed rating.
https://www.youtube.com/watch?v=I5QTqLn5mL0
Replace them sooner than later. Always check air pressure prior to leaving anywhere. Do a visual inspection of the tread. Look for strange bulges in the tires. Always include your spare in your checks.
I did all the above. The first tire to go was the spare, i had grown a large bulge. Had it replaced. Went on trip, 1st tire blew out 15 minutes from my destination on a very busy I-26 in Charleston, SC. This blow out caused over $4k in damage and took almost 9 months to get everything fixed. 2nd tire blew 15 minutes from getting home on the same trip as the 1st blow out. Occurred on a very bust I-77 in Columbia, SC. Luckily, this one did not damage.
Lost 3 Castle Rocks in a 2 week period. I did everything you are supposed to do in regards to caring for my tires and do not overload my TT.
