pjay9 wrote:
I have been reading this post and all the great info. I had wondered if the commercial scales would even bother with us little guys, but a buck is a buck to them.
I find it very easy to use a scale that is not open to do what ever I want. In WA along I 90 there is a scale on the eastbound lanes on the east side of the pass. I rolled in took all axels, unhook trailer by itself, moved to do tongue wght, then did truck by itself both /each axel, then I took each wheel of the truck...very interesting the side to side differnce...but the whole rig came in at less than 18000# (close enuf)... Truck fueled at 3/4, TC with food water full propane empty waste and boat 1/2 fuel (23 USGal), fish gear, downrigger balls, and kicker. Will try to find in my log book the exact numbers and post later just so you can see the each wheel info.
Good to know if I need a scale I can roll in to a truck stop.
Log book entry:
Frt Axel 4180
Rear 8900
LF 2100
RF 2080
LR 4500
RR 4380
Yes it is 20# dif, that is a margine of error!
That is weight without me on board...
since I was doing this by myself.
With BT Trlr
F 3980
R 9960
BT 3780 BT alone 4180
17720
On my 9700 mile trip to Everglades and back:
F 4000
R 10140 Had my aft storage boxes full of stuff
BT 3600 Lighter...took a bunch of fishing gear off
17740
It seems my all up is staying about the same, no matter my config. I am happy I have the 19.5's!
WOW, THANKS.
I just started looking at Truck Campers. My focus will be to drag a small boat trailer or a larger weight distributed trailer with the boat n trailer inside along with other toys.
I have an 2006 Dodge DRW 5.9L Diesel Quad cab which looks to be just like yours.
Your post really helps me put things into perspective, thanks again.
Bob
PS, Play 9; Do you know the overall height of your unit? Do you have a AC unit on top?
Also, tell me about the benefit of the 19.5 " wheels ? Obstruction clearance?. TIA
