KMP44
Aug 07, 2014Explorer
You want to use a caulk made for RV's - not household caulk like silicone. Dicor is the big name, but there are some others. You want the self-leveling product for the roof. But make sure you don't use the self-leveling stuff on vertical surfaces - just the standard Dicor.
Eternabond tape is also an option for your roof seams. This is more expensive and requires chemical prep, but if you plan to keep the Kodiak a while, Eternabond is a one-time application. Once you cover the seams, you shouldn't ever have to do it again.
