myredracer
Feb 22, 2017Explorer II
ducky_07 wrote:
Its the main ceiling, not the slide out ceiling.
There is snow on the entire trailer, any reason why only 2 panels would be bowed?
Any light fixtures, speakers or anything else on those particular panels? Sometimes (always?) the ceiling panels are only attached at the edges of the sheets and it doesn't take much for them to bow downwards. Can you see evidence of staples between the seams of each sheet? Things like AC grilles, roof vents, AC unit, etc. will secure the ceiling panels up tight against the rafters. Could it be that the insulation has gotten damp over time and the weight of the insulation is causing the panels to sag? Interior moisture buildup and water ingress can be the kiss of death in RVs.
What is the history of use for the TT? Had a lot or little use in the winter? Improper venting of moisture in the winter can trap moisture in ceilings (and walls). I would pull down speakers, vent trims, etc. and look into the ceiling cavity and reach in and see what the insulation feels like. What happens if you push up on the panels? Resistance or is it lightly floppy? It could be nothing and resolved with stapling the panels a bit (with the correct type of staple).
The owner's explanation doesn't sound reassuring. For a small amount of $$ you could hire an independent RV tech to inspect the TT. Could potentially save you thousands of $$ in the long run. Maybe post a pic or two might help.
