plasticmasterExplorerDec 07, 2015ceiling panel joints?The ceiling panels on the inside of my TT have thin white strips that cover where the panels join up to each other. They are about an inch wide. Where can I purchase these strips? Thanks.
the_bear_IIExplorerDec 07, 2015Are you talking about tape type material or strips made from plastic or wood ?If it's the tape type you'll need to go to a wallpaper supply to find a replacement. You use heat (iron) & pressure to make the tape stick.Plastic or wood look in the molding section of a home center.
Related ContentFuse panel locateCeiling fanCeiling panels..replacing inside panels and ceilingHelp Tiffin ceiling panels falling down
