ktmrfs
May 20, 2022Explorer III
Tom_M wrote:
I have a WeBoost Sleek which uses 75ohm cable, but to use RG6 would require an adapter on each end to adapt the F type connectors to the type used on the Sleek.
those are readily available.
We also have a WeBoost 75 ohm system in our trailer.
There are several weBoost amps that have a 75 ohm output. The advantage is that low loss 75 ohm cable is much less expensive and much smaller diameter and much more flexible than low loss 50ohm cable of the same loss. A distinct advantage and the ability to have the antenna 25+ ft from the amp input to avoid oscillation from feedback.
Just make sure you also use a antenna matched to 75 ohms.
