rooney77 wrote:
Are you asking whether you put them on the inner tires or the outer tires? Or front vs rear?
Really between front and outer rear. On one hand with the camper there is far more weight on the rear tires. Putting them on the rear would help prevent the rear from "swinging out" as well as giving you better "push." On the other hand putting them on the front would give you better steering control as well as some "pull."
I really would prefer to avoid them entirely but in Washington State all vehicles over 10,000 lb's are required to put on chains whether or not they are four wheel drive.
