thomasmnile wrote:
Huntindog wrote:
Make sure that the AC is working right. Does the AC work OK on shore power?
If not, then it's a AC issue. The Champion should run the AC just fine.
As others have noted, a little power management may be needed.
Wonder if the OP has a hard start capacitor kit on his AC. Would that make a difference? X2 on power management thought.........
That Genny should be more than enough to run the 13.5 AC he has. He has other issues of some sort that is preventing it. Low battery that is causing the charger to pull a bunch of juice, hot water heater running on electric at the same time he's trying to start the ac or some other drain on the electric the genny is putting out. If the gennys working right, it's more than enough to run that AC and a few other appliances without issue.
