time2roll
Oct 30, 2017Nomad
4.30 will put you right at 3000 rpm.
4.56 you are looking at 3180 rpm.
Downshift will put you at 5070 and 5380 rpm respectively.
Is that where you want to be?
I also needed a tuner to correct the speedo (you may not). I used this to reduce my shift points 500 rpm. I really do not need to be at redline when towing. This also helps prevent the downshift.
44,072 PostsLatest Activity: Aug 23, 2026
