Huntindog
Nov 08, 2017Explorer
mkirsch wrote:Not really.
If your 2008 Burb still has the 4L60E in it, you probably don't want to re-gear it so it can tow in OD, because the OD gears in those transmissions are reportedly weak, or so I've been told, and read in multiple places such as this site.
Another thing you do NOT want to do is regear and end up turning the same RPMs in OD as you were in direct before the gear change. You've gained nothing from a bunch of work and expense.
In fact this can be the best possible swap in many cases. You simply would not us OD when towing, when mileage will be terrible anyways, and have OD available for better MPGs when not towing
44,071 PostsLatest Activity: Aug 16, 2026
