LarryJM wrote:
BurbMan wrote:
LarryJM wrote:
04 service manual for the 4l60-4l65-E says 5 quarts for pan removal. Complete flush, including converter is approx. 12 quarts.
Thanks for clarifying. You can change your transmission fluid any way you like :B
No problem and unlike some others just doing a pan drop and fill is sort of like doing an engine oil change and putting 2/3s of the old oil mixed with 1/3 new oil back into the engine.:S Not what I consider a good maintenance practice.:R
But as you said one can do the maintenance whatever way they want.:W
Larry
WOW. Some people just assume. Just ask someone that does the transmission work at a dealership which one is best. He will explain why and you will never flush it again or maybe you will.
