docnascar's avatar
docnascar
Changing transmission fluid
My 2010 silverado is creeping up on 30k miles. I pretty much only use it for towing or hauling something. Tranny temps while towing are typically around 200-220 and some minor runs at 235 on large grades.
I've always been the person that never changes tranny fluid on my vehicles. Probably won't on any of my cars going forward. However, this truck is the "work horse" and I'm pondering if I should, since its being used harder. I say harder because the max tow rating of this truck is 4700lbs and my camper is ~3500lbs.
Thoughts?
  • IMO you would be dollars ahead in the long term to follow GM recommendation on fluid/filter change on the truck.
  • What does the owner's manual say? What does the fluid look like?
