POLORBR wrote:
What is the most efficient way to charge batteries with a generator? Is using the 12 volt DC charging cord connected directly to the batteries any more efficient than plugging the camper power cord into the generator. Why? Just curious. Thanks in advance.
what year is your RV?
the newer RV's usually have a decent onboard converter/charger, and it is usually the ONLY way to charge the batteries...
so no matter if you are plugged into shore power, or running off the generator, the 120vac power coming in goes into the converter and comes out as 12vdc, and on to the battery.
the only way to get your batteries to charge quicker is to get a higher amp multiple stage smart charger... and depending on the size of your battery bank, it may be charging to its full potential on the charger you have.
1 or 2 G27 batteries can only use about 45amps of charge, so a bigger charger is not beneficial, but if you have 3 or more G27 batts, or larger/more batts, a 60-80 amp charger could help you..
