Frank_Mehaffey
Oct 16, 2018Explorer
Ok, now THIS should be my last post on this subject. This is the email back from Ford from someone who did some research with a techie.......
Hello FRANK,
My name is Elle, I am from Ford`s Customer Relationship Center (CRC). I have reviewed your email inquiring about:
The rate of charge delivered from your 2012 Ford F-250, while running, to a camping battery through a 7 pin plug.
Per our technical advisement, while there is no published specification for this, we do know that the max output is 10 volts at 25 amps. However, the power is controlled by a control module, which will cause the exact numbers to vary.
Thank you for contacting Ford Motor Company.
Sincerely,
Elle
Ford Motor Company
C'est fini.........
Hello FRANK,
Sincerely,
Elle
Ford Motor Company
C'est fini.........
44,059 PostsLatest Activity: Mar 18, 2026
