theoldwizard1
Oct 21, 2018Explorer II
ticki2 wrote:
Now I'm confused again , which doesn't take much any more . If 13.2v is a fully charged 12v battery then that or anything above will eventually fully charge the battery.
How long do you want to wait ?
I go by what the battery manufacturer recommends
ticki2 wrote:
I just did a quick check on mine and after start up the truck batteries are showing 14.7v and the camper batteries, two T-105, are showing 14.2v with 4ga from truck to camper , so it doesn't appear that my truck has smart charging.
Try your test again but drive the truck for about 10 minutes and tell us what the voltage is at the vehicle battery withe engine running and at your house battery bank.
Trojan specifically calls for 14.8V for Bulk Charging, 13.5V for Float Charging, and 16.2V for Equalize Charging.
If your vehicle charging system is supplying a constant 14.2V at the house batteries, you are cooking them !
(Segue - the only multi-stage battery chargers that meet Trojan's specs are ones that allow the end user to adjust the voltages at each stage.)
44,059 PostsLatest Activity: Mar 18, 2026
