2003silverado
Mar 10, 2015Explorer II
charging system voltage.
My truck is a 2012 Silverado 2500hd 6.0 liter gas with 40,000 miles that I've owned since new.  A couple months ago I notice that the voltage gauge was running quite a bit above the 14 volt point in the middle of the gauge. Since then it has been between that point and just a hair above the 14 volt center point.  When I got home today I noticed it was at the high spot again so I left it running and fetched my volt meter and 15.12 volts at the battery.
Is that too high? Seems like I've always known charging systems to run around 14 volts. But it also seems like as computerized as these newer vehicles are I would get a message on the dash of too high of voltage. Wondering if I have a faulty voltage regulator.
