Bedlam
Jul 31, 2014Moderator
DiploStrat wrote:GoFish wrote:
… is there a way around this without having to rewire everything?
No, because it is the small wire, and distance to your camper, that is limiting your charge rate.
You can run additional wires from your current setup to increase charging without janking what you already have installed. If your current charge wire is #10, you can run one or two additional #10 wires in parallel with your original run to boost charging capacity.
