Bobbo
Dec 01, 2013Explorer III
Check Engine Light
I have a recurrent problem that is triggering a check engine light. It has been in the shop multiple times and they can't find the problem. However, I think I have finally detected a pattern, and want to know if you can tell me what it means.
The error code is the same code that you get if you leave the fuel cap off, an evaporative emissions code. I don't remember right now exactly which one.
However, if I clear the code, it will not trigger again if I keep the fuel tank above 1/4 full. It is only when the tank is 1/4 full or less that the code gets thrown.
If you need the actual code, it will take me several days to drive the fuel level down to where the code is thrown again.
Thanks for any input.
