camp-n-family
Jan 25, 2020Explorer
BenK wrote:
This ^^^
Looks is just surface or a facade
A 16 lb sledge looks like an 8 lb sledge...a 12 oz hammer looks like a 16 oz hammer, but there is a huge difference
Ditto 2 tires from same OEM, same model, same tread, same size...but one is a passenger class and other higher class LT. Very different...costs more, weighs more, better construction, etc
I don’t buy the heavier is better hype at all. Only way to know is to compare them side by side. Lighter doesn’t always mean less or weaker. I have a friend with the exact same layout tt as mine from another manufacturer. We compared them. To start, his is 1100lbs heavier from the factory.
My lighter tt has heavier rated axles and higher load rated tires. Mine has heavier duty slide gear. Mine has a bigger a/c. Mine has aluminum framing everywhere vs his wood framing. I have solid wood cabinet doors where his are heavy laminated MDF. We both agreed that the quality and fit and finish of mine was better and it’s been aging better too.
