Bedlam
Aug 06, 2015Moderator
When winterizing, I drain the hot water tank and blow out the water lines at all faucets and low points. I do not use the bypass or add pink fluid to the lines. I will dump some antifreeze in all the drain traps.
Now that I have power to the TC when ever I need it, I set up a small space heater inside when I know temperatures will drop bellow 30 degrees and keep the interior about 50 degrees. this is warm enough to prevent any of the plumbing or hot water tank from freezing on my camper.
