- Boon_DockerExplorer III
LeBout wrote:
Checked my batteries the proper way and got a good strong reading (13+ volts). I will check them again at the end of our driving day.
Good to hear that you got it figured out. :C - LeBoutExplorer
bob213 wrote:
Take a look at the red 6v batteries here and make sure that is how you have them hooked up.
12 volt side of life
Yes, I have them connected in series. Positive to negative. - LeBoutExplorerChecked my batteries the proper way and got a good strong reading (13+ volts). I will check them again at the end of our driving day.
 - LeBoutExplorerNo, the batteries are connected in series, positive to negative.
 - bob213ExplorerTake a look at the red 6v batteries here and make sure that is how you have them hooked up.
12 volt side of life - MFLNomad IIYes, while I said parallel, the two 6Vs would need to be in series to achieve the proper operating voltage. IIRC, I think it was mentioned in other thread, "now everything is working properly". If that was the case, then maybe improper measurement is the problem.
Jerry - wnjjExplorer II
Boon Docker wrote:
LeBout wrote:
MFL wrote:
To get the paralleled voltage of the two 6s, you need to do the pos of one battery, and the neg of the other.
Jerry
It's weird. Whether I test one battery on the positive and negative terminal or whether I test the positive terminal of one battery and the negative terminal of the other battery I get the same reading. About 6.5 volts
It sounds like the two batteries are connected in parallel (positive to positive, negative to negative) instead of in series (positive to negative).
Or the measurement is actually being taken between pos and pos or neg and neg. - Boon_DockerExplorer III
LeBout wrote:
Jerry
It sounds like the two batteries are connected in parallel (positive to positive, negative to negative) instead of in series (positive to negative). - enriquecruz8519ExplorerI always test each batteries separately for the 1st time because if you have different charge levels on each battery it uncertain condition for the road. However after few charge cycles it doesn't require much attention.
 - LeBoutExplorer
Jerry
44,052 PostsLatest Activity: Oct 29, 2025
