drenjoey's avatar
drenjoey
Chemical.....Deodorant
Just curious......I know most of us if not all, put toilet chemical or deodorant in the black tank.
My question is: Does anyone put anything in their grey tank, which would be chemical in a liquid form.
Thanks
Dre
  • Black tank I can see because you open the valve and the smell can waft out; but grey tank should always have a water seal between you and the tank so no smell enters the coach. If you have a bad smell in your coach from grey water THEN YOU HAVE A PLUMBING PROBLEM that needs to be addressed.
  • I wonder how folks that say no odor operate the bath fan. They must turn off the bath fan, and any other fan, till all air flow stops before flushing. I can operate my fan in either direction and speed, but there is no perfect answer so anti-stink chemicals go in the tank.
  • rockhillmanor wrote:
    This in the black tank.
    This once a month in the gray tank to de-grease the sides and sensors.
    Mrs. Meyer's Clean Day 32 oz.
    Lemon Verbena Multi-Surface Concentrate Cleaner
    My sensors work ALL the time.
    Lemon Verbena? Sounds like something they push around on the desert cart lol.
    There are no smell in my camper. I just thought that after a while, there are residue that will stick to the walls of the grey tank, and there must be a product that should get rid of those.
  • jjjandrbaker wrote:
    First of all, I don't put anything in my black tank but water. I have never had any odors. As far as the grey tank, I would assume that bath soap and dish soap going in there would keep it odor free. Unless you are putting food scraps down the drain, which I make sure I do not, I can't see anything that would cause a smell. If I have questionable liquids from cooking, I always put them down the toilet.
    And that just means all the grease etc will stick to the sensors in the black tank instead of the gray!! :B
    drenjoey wrote:
    We have bacon and eggs in the morning, we will rinse our plates over the sink.....We have pasta for dinner, we will rinse our plates over the sink.
    Not all of that stuff will come out when you empty the tank. Stuff will stick to the grey tank walls and eventually cause a smell.
    As for the black tank.......My $%^& smells and putting chemical does help.
    X2
    Exactly!
    And for those that are the nay sayers? That is also why your sensors don't work.
  • darsben1 wrote:
    My sensors work and always have
    Mine work ...... I think ...... not really sure ..... don't care
    Haven't looked at them in over 9 yrs. ..... I dump when full then rinse/flush and fill them up again ... repeat when full
    X2
    Exactly!
    I'm happy I'm not the only one who thinks that way
  • I might try that Lemon Verbena Multi-Surface Concentrate Cleaner
