- shades9323Explorer
kmac7800 wrote:
However they have the smaller size stem (.435") and only go up to 100PSI. Not made for 16" or larger tires. You can get larger stems, then you are limited by PSI.
Good luck!
//KMac
Current camper has 13 or 14" tires on it and inflate to 50psi so we should be good to go. - shades9323Explorer
lly-zf6 wrote:
I have them installed in my 5th wheel and dump trailer both.
Have been using them for about a year with no issues.
But, so you know, they do not show up on the DIC like the truck tire sensors. They show up in the trailer page of the radio. You can set limits so they will alarm if they go to low.
Good to know! - kmac7800ExplorerHowever they have the smaller size stem (.435") and only go up to 100PSI. Not made for 16" or larger tires. You can get larger stems, then you are limited by PSI.
Good luck!
//KMac - lly-zf6ExplorerI have them installed in my 5th wheel and dump trailer both.
44,066 PostsLatest Activity: Apr 10, 2026
