ridinpreacher's avatar
May 28, 2014
chevy 3500 6.0 vortec and truck camper
Is anyone using a chevy or gmc SRW or DRW with the 6.0L with any of
the single or double slide truck campers that are out there.
The Lance and Palomino double slides push 3700 lbs. even over 4000
considering the Lance 1172.
Bottom line are these dually only diesel only once you get to 3700 and over?
  • There is no SRW truck that is going to have 3k# payload capacity just based on tire capacity. If your over 3k on the TC you need a dually. As far as the Chevy 6.0 goes it's not a problem just try to get the 6speed trans for a better experience.
  • You should be fine. I've carried one of my campers weighing around 3000# and 4 people on a f150 From Okla to the west coast and back. But I wont do that again. :)
    The 1172 is going to be VERY far over 4000#.
    However, keep in mind that the NNBS 6.0L Chevys have 6 speed transmissions which make for a much more relaxed ride than the older 4 speed trans. And the 6 speed seems to find better gearing for most situations.
    Our 2012 Chevy crewcab 6.0L/ 6 speed easily hauls our Lance 855s
  • With GM and I believe Ford trucks if you look at 2011 models and newer you will get a much higher payload than before that date whether it gas or diesel. I don't know what year Dodge raised its payload.
    Paul
  • That said, is there a "best year" for the 6.0L vortec? It seems to me it would pay to go new enough to get the 6 spd trans.
  • Thanks. I currently have a 96 with the 5.7 vortec and numerous bolt on performance modifications and it does fine with our Lance 835. Absolutely smooth sailing. But, the 96 is a 2 door model extended cab and as we get older it gets to be a pain and a newer truck with rear doors (whether xcab or crew) would be easier on our backs for making use of the rear seat for carrying those things we like to have in the cab of the truck, to say nothing of being able to take our grand kids with us!
  • The 6.0L engine is more then enough power for hauling any TC in both SRW or DRW trucks. My neighbor pulls a 5vr that weighs about 10k with his 3500 SRW 6.0L.
    Now if you're considering a 4000# TC I would be looking seriously at a DRW truck.
