AlmostAnOldGuy wrote:
jaycocamprs wrote:
Have a 18 SCREW company truck, 12k since new running 23.5-24 over that 12K miles. That compares to the 11 reg cab F150 with a 5.0 that it replaced got 19 MPG over the 40K I drove it. I run a lot of highway miles with no load.
How do you like the 2.7 compared to the 5.0 re: rpms, holding gears, general impressions?
Take it easy,
Stu
For what I use the truck for it's fine. Holds gears well, and gear spacing is very close. RPM stays pretty low, often don't notice the 10-9 down shift. Always seems to be in the right gear, none of the this gear is to low and the next to high. Runs about 1900 rpm @ 75 mph. Never towed with either truck, that's what the DuraMax is for. It does shift more than the 5.0/6 speed, but not badly. I would likely spring for the 5.0 if I was going to tow, the 2.7 does not hold back well at all. Lot's of go, just no whoa. And I don't like the engine stop start on the turbos either.
I find the 18 Ford cab harder to get into than the 11 ford or my 18 Chevy. My knee hits the light switch and the steering wheel doesn't go up enough, fine once in but...
For hauling me and my suitcase around it does good. The increased mileage of the 18 plus a bigger fuel tank than the 11 is good thing
