falconbrother
Mar 04, 2017Explorer II
Camper G wrote:Mkos1980 wrote:
The newer motor wouldn't be able to work with your current ecm. The reluctor ring on the crank is differant. They would have had to use a 5.3 with a 24tooth ring vs a 58tooth and all of those were 04 or 05 and prior.
You beat me to it. Exactly correct. The 14 and newer 5.3L are a completely different engine than the prior generation 5.3s. Not saying it could not be done, but it would be a TON of work and not very likely in your case. The newer Generation 5.3s take 8 quarts. The owner's manual is wrong, it was later corrected to 8 quarts. I hope it was just a fluke thing in your case and all is well.
Just by looking this engine seems to be dressed like the older Vortec, not that I know anything about the 14 and up design. But, I can't figure out why the dipstick would read incorrectly, assuming it is incorrect, which I don't believe at this juncture. It's a long dipstick that is like a two piece that is scabbed together about halfway down. Let me go get a picture. Does this look like the stock dipstick in a 5.3 Vortec?
44,071 PostsLatest Activity: Aug 30, 2026
