armyhockeynut's avatar
Jul 18, 2017
Chevy Auxillery Battery
I have always been curious about the auxiliary battery that is in my 2001 Chevy Silverado 2500 HD. According to the manual, this battery is for if using a truck camper? That would lead me to believe that if I am not using a truck camper, I dont need this extra battery?
When I recently had to replace the batteries, I was told I should replace both?
    If it is a desiel then you should replace both, they are paralled and are your starting batteries.
    If it is a gasser, then it is the auxilary battery that is an option. the aux battery is for a camper, etc.
  • If they are saying that it's for a TC then it must be a dual purpose battery? An automotive battery will die pretty fast if used on an application that discharges it the way we do gc2 and marine/rv batteries. Is it gas or diesel? I haven't seen them all but diesel usually uses two because of cranking amps, grid heater etc.
  • Diesel? My three Ford diesels all have had 2 batteries, but they are simply wired in parallel to provide the power for starting the diesel engine.
