rhagfo
Nov 02, 2016Explorer III
blt2ski wrote:
Yes, go for 45psi. If you do not get a full contact patch on the road, go less. If you have full contact patch, then you could go higher, but only do 5 psi increase or decreases. I run 50 on the rear of my 00 C2500 reg cab, I only have 2400 lbs on the rear empty. No need to run 80 with 6100 lbs of capacity. real rough ride.
Marty
Yes, softer ride, full contact with road means less tire spin starting out in slippery conditions.
44,071 PostsLatest Activity: Aug 16, 2026
