Grit_dog
Nov 02, 2016Trailblazer
seekingsummits wrote:
I double checked and this truck as the 265/70r17s on it with a 75psi rating on the door sticker. For running down the hwy unloaded would folks really recommend running down to 45psi? Ive not ran LT tires before, only P series and have just never under inflated that much other than for offroading so just curious if folks would really go that low
Think of it this way. Air pressure is holding up the vehicle, not the strength of the tire. So if your half ton then a slightly heavier, on the rear axle, 3/4 ton will be happy with slightly more pressure.......with the ability to air up to 80psi to carry significantly more load.
44,071 PostsLatest Activity: Aug 16, 2026
