wayfun wrote:
I pull a Jayco 25RKS with an '09 Tahoe with the full trailer package and 6.2L engine and 3:42 rear end. There are a series of codes on a placard in the glove box and one of those codes denote the rear end. Sorry I don't recall the codes but if your search you can probably find them on this site. With the 6 speed in tow mode it holds in 4th gear most of the time unless you are on flat ground or downhill and then it may upshift to 5th. If I recall correctly it runs about 2700 rpm in 4th.
Thanks. I didn't know the 6.2 was an option on the Tahoe - I thought it was only on the Yukon Denali?
Are you happy with your Tahoe?
