BenK
Apr 09, 2021Explorer
Ditto a large external ATF cooler.
If you have the tow package, there already is one and add a 2nd in series to that OEM
If no OEM external ATF cooler, install it on the hot line from the tranny...DO NOT use a saw to cut the tubing...use a plumber's wheeled cutoff tool.
Stacked plate is best, but tube-fin also good. Just bigger vs same cooling from a stacked plate
Suggest while at it...change the ATF fluid to synthetic
