JRscooby
Jan 09, 2021Explorer II
Bolt a rubber mudflap to the boards so the tire is on the rubber before it pushes the board. But you might want to dig the snow/ice away from where the ramps sit. Heat from trailer might melt causing you to put extra force on stabilizers.
If my plastic ramps are on asphalt I unplug the trailer so less likely to slide when I touch brakes.
