noteven
Jan 09, 2021Explorer III
What I would do on Canadian ice or hard pack snow is put a full kettle on the stove to boil, go out and place the levellers. Pour a bit of hot water over them so it melts them in a bit. Then go have coffee or tea while they freeze in. To release them drive off and then give them a couple gentle hits with something heavy - chunk of firewood - to break them free. If you overdid the hot water freeze in you might have to use hot water to thaw them free again. If your water tank is empty snow turns into water when you heat it, but it takes a lot of snow.
